Old 10-04-2009, 01:30 AM   #3 (permalink)
RandomFact314
My Goal: 35 MPG All City
RandomFact314's Avatar
The Neon - '00 Neon
90 day: 25.38 mpg (US)
G/F's Car - Kyan - '01 Rio
90 day: 23.94 mpg (US)
The Accord - '97 Accord LX
90 day: 22.41 mpg (US)
Lizzy (all city) - '88 CRX Si
House of Tudor
90 day: 31.92 mpg (US)
Originally Posted by Christ View Post
It's in the right place, that's sure.
Do your fog lights work?
Do you have saran wrap?
Can you get access to some spray foam?
Tag off an area of the lower grille that you'd like to block, layer it with two layers of saran wrap, and spray it full of foam in layers. As soon as the foam is thoroughly set up, you can remove it, poke holes through it, and use it for a plug to AABBAABBAABBAA (etc.. you get it.) test whether it's something you're interested in doing.
You can do the same thing w/ the upper grille, if you'd rather try it there first. Upper is better, since the lower portion is already aerodynamically "dirty".
Thats where I dont get it, if the bottom is "dirty", why would you not do it on the bottom to "clean it up"???
