Old 10-04-2009, 01:50 AM   #7 (permalink)
RandomFact314
My Goal: 35 MPG All City
RandomFact314's Avatar
The Neon - '00 Neon
90 day: 25.38 mpg (US)
G/F's Car - Kyan - '01 Rio
90 day: 23.94 mpg (US)
The Accord - '97 Accord LX
90 day: 22.41 mpg (US)
Lizzy (all city) - '88 CRX Si
House of Tudor
90 day: 31.92 mpg (US)
Originally Posted by Christ View Post
You make a plug with it. You layer the Saran wrap so you don't get the foam on the bumper, then once the foam is set, you can remove the whole plug from the bumper. It's easier to do it that way, since it allows you to remove the plug for testing or hot days. Also, it will allow you to remove it for whenever you decide to layer fiberglass over it and make a real plug, instead of just using a hunk of foam.
Alternatively, you could glue a bunch of insulation foam board together and just trim it to fit in there snugly, and that will achieve the same end.
Yeah I would like to have one of these two options in the end...
(1st choice) the fill in that looks natural
(2nd choice) the fiber glass (or whatever that is) that you can pretty much see right through
