As Ben I'm sure can tell you, it might be worth it if it has things like working brakes, it also appears to be an aluminum frame and comes with what I assume is an expensive exhaust system, along with some spare parts, and most of all, a title, if you could hook a battery up to it and have all the electrical for lights and so on work, then I'm sure it would be well worth it.
