Old 10-05-2009, 08:50 AM   #2369 (permalink)
adamj12b
EVVette - '71 Corvette Coupe
O, I also forgot, To add USB to the controller might not be worth it. You would have to source an FTDI serial converter chip, and there not all the same. Some work better then others, and drivers are usually necessary. Also, Im don't think I have ever seen one that wasn't surface mount. I dont mind soldering that, but it is tough to solder 40 pins around a square 1/2".
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
