Originally Posted by Cd
Adding some more to this dead thread. Sorry for "beating a dead horse".
Here is an image of the car shown above as it was tested in the wind tunnel.
Of note would be how that the barn door flat front end of the car has even less of a radii than the white Camaro, no 'moonies' for the deeply inset wheels, and ( rear ) tires which stick out directly into the airflow. As shown in this image, the Cd was .292
Reading over this thread, I have to apologize for misspelling " Cd " as .Cd - as was pointed out to me, there is not period before "Cd".
I'm learning.
I also found this image interesting. The windshield is near vertical, yet there is attached flow along the roof. I guess this is a good example of how little curvature is needed to retain the airflow.
in one of my SAE papers,the researchers found that for their passenger car,a 40-mm radius was all that was necessary to achieve attached flow at the leading edges.That's not to say that it's the lowest drag radius,just that there's no separation.
