Never underestimate the ability of an idiot to screw things up! I once bought a 57 Chevy parts car and when I pulled the motor I found that whoever put the pressure plate in put it in backwards so the springs hit the heads of the flywheel bolts. It was then driven that way for some time since the flywheel bolts had a groove worn into them and those aren't soft bolts!
