Old 10-05-2009, 09:14 PM   #14 (permalink)
some_other_dave
If you're not buying lines made specifically for your car, you will probably need to bend the new lines. (Check to see if there are any bends.) I strongly recommend a real tubing bender to replicate the bends, because it is less likely to crush the tubing than most other DIY methods.
-soD
