...most diesels are low-rpm (compared to SI-engines), where LONG strokes are used to capture & maintain more "flywheel" affect...maximization of torque.
...the faster you want the engine to turn, the SHORTER the strong typically needs to be...of course, at the expense of some amount of torque.
...the REAL question, however, is "...how strong..." is the block because of the MUCH greater cylinderwall pressure of a diesel (20-22:1 CR) over gasoline (8-10:1 CR).
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SIDI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
