Old 10-06-2009, 05:35 PM   #120 (permalink)
aerohead
body rake
Originally Posted by Cd View Post
MeanJoe, I'm looking at that roofline on the hot rod in the post above yours. The flow certainly seems to be attached - despite the vertcal windshield.
I never would have expected this :0
I see what you mean about the pressure changes upstream . At the base of the windshield, the air is swirling and creating a smooth flow for the approaching air which slips above it ( It is " getting out of the way"as you say. )
Cd,if you had a photo of the hot rod from the side,you would see that the body has a little "rake",where the nose is dropped in relation to rear.That would have the top of the roof "leaning" into the oncoming air and in a positive pressure gradient.As long as the air isn't tripped at the windshield header,it continues to be rammed onto the roof.
