Old 10-06-2009, 06:24 PM   #5 (permalink)
mwebb
mwebb's Avatar
1996 geo metro - '96 metro base
if you are "Teed" into the Purge line , when the purge valve is duty cycled by the ECM / PCM
the vacuum gauge will pulse with the duty cycle .
17 to 18" at hot idle is too low at sea level
but more important is that at hot idle there should be ZERO flutter in the needle
the brake booster vacuum line has a check valve in it ,
if you "T" into the line after the check valve the vacuum value you measure will be incorrect.
