Old 10-06-2009, 07:59 PM   #21 (permalink)
dwtaylorpdx
There is a basic relation ship to the temperature of the incoming exhaust and the speed of the turbo due to the temperature drop as the exhaust gases expand in the turbo but its not much.
On many race cars the alternator is driven by a belt off the pinion gear of the differential. It reduces the load on the engine in the vehicle because its taking advantage of the gearing at the output end of the transmission. It also means the alternator spins at a more consistent RPM and does not see the extreme rpm's at WOT.
Its also only charging when the car is moving, if you added a field switch to the gas pedal it would only charge when your foot is off the pedal. (Coasting) This might work for reducing the charging cost of the vehicle? Might be a intermediate way to extend the distance of a vehicle that is running without a alternator currently but not go to a full time alternator, could even be a downsized alternator, (Mitsubishi forklift alternator) that has like a 45 to 55 A output.
Just thinking..
Dave
