Old 10-07-2009, 01:46 PM   #84 (permalink)
racprops
Injector
What make and model car are you talking about??
I know chevy came up with something that sounds like what you talking about, a center one or two injectors with feed tubes to send the fuel to the cylinders, a crappy system... but it worked..like on the V6 in a S 10 pickup.
Should be able to get to the center injector and hook up.
Rich
Originally Posted by Eddles View Post
Got mine a long time ago, but still not fitted it as not 100% sure where to get the injector signal from and don't have time right now :/ It's not quite that easy for my car as the injectors are just glorified metal tubes - the actual metering is done internally in the fuel pump itself where the injector computer is also located. My only chance to get the MPGuino working is to find a wire carrying a pulsed signal from the main engine computer to the injector computer. However, I believe my chances of finding this wire is fairly slim.
