back in the 70's i deactivated the valves on two cylinders of my civic, and the mileage wasn't measureably improved. plus i had to drive in the truck lane.
I think the most efficient IC engines are the big bore, slow turning, compound turbo'd, diesels in trains and ships. around 30% Of course constant speed with electric drive trains not transmissions.
So one might infer that reving a smaller engine to high heaven to get enough power, probably won't help your efficiency. more fiction
and turboing a Geo to 15psi might shorten the life.
Chevy shuts down the same four cylinders all the time by collapsing the valve lifters and not energizing the fuel injector.
