Old 10-08-2009, 12:14 PM   #2 (permalink)
metroschultz
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
The IACV should not be adjustable.
It sounds as if yours , or your throttle, is stuck partway open.
Have you taken the throttle body off and inspected it yet?
You may find the throttle hung open by some carbon or other foreign material.
You definitely need to check for a hung throttle plate before you adjust the TPS.
Is yours fly by wire, or conventional?
I had a Fly by wire Toyota the other day with a similar issue (always over idle, MAP code) that just needed the Throttle body cleaned up.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
