Old 10-08-2009, 02:22 PM   #3 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Originally Posted by metroschultz View Post
The IACV should not be adjustable.
It sounds as if yours , or your throttle, is stuck partway open.
Have you taken the throttle body off and inspected it yet?
You may find the throttle hung open by some carbon or other foreign material.
You definitely need to check for a hung throttle plate before you adjust the TPS.
Is yours fly by wire, or conventional?
I had a Fly by wire Toyota the other day with a similar issue (always over idle, MAP code) that just needed the Throttle body cleaned up.
Backstory - I just replaced this engine.
So yeah, I've checked/cleaned the TB, removed and replaced the IACV 3 times, changed the TPS (and it needs to be adjusted now) and the throttle plate is adjusted to the point where it is just barely not contacting the throttle bore.
On some cars, you can adjust the IACV's counts, but on others, you can't. I haven't found a feature with my scan tool that will let me do it, but some you can also just unscrew a little bit and reinstall. It's quite unfortunate that I don't have an airflow meter or a way to tell how far open the IACV is at idle. The car normally idles high, so maybe I just need a new IACV.
Frankly, I'm going to adjust the TPS anyway, because I'd rather have it set to 0 at NOT than 18-20%. Right now, it goes to 100% just before it's actually open 100%, so I'm actually going further than the pot will read.
There's a little bit of slop in the screw holes, so I'll try adjusting with that first, but if it doesn't come within spec, I'll slot the holes and adjust further.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
