Old 10-08-2009, 02:11 PM   #164 (permalink)
theycallmeebryan
2003 Ninja EX250 - '03 Ninja EX250
90 day: 87.63 mpg (US)
Saturn - '99 SL1 Base
Originally Posted by The Atomic Ass View Post
I can't argue with the cost... But I was under the impression the motor had been massaged for more low end torque, which I think would have benefited FE at least somewhat...
Members of ninja250.org with the newer bikes seem to be getting less FE than those with the older generation. I'd put the blame on a few things. Not only have the new ninja 250's suffered in the aero department (it looks flashy, but...), the new ninja's are a bit heavier , too. The new ninja 250's have a wet weight of 376lbs, where the old ninja has a wet weight of 355lbs. The new Ninja 250 is tuned a bit differently than the pre-08's, which provides more low end and mid range power, at the expense of top end. Also, the new 250's have less compression (11.6:1 vs 12.4:1 on the older 250's).
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
