Old 10-08-2009, 09:57 PM   #12 (permalink)
Matt Herring
Matt Herring's Avatar
Bone's 2010 Prius - '010 Prius Black
90 day: 56.78 mpg (US)
Originally Posted by armycopter View Post
Not to get too far off-topic Matt, but can you recommend a good aftermarket EBH?
I purchased mine through priuschat.com through Toyota of Canada. I'm not sure if it will also work on your car but maybe because it's a Toyota part. If you go to priuschat.com and click on the store you will see the one I use (but it has a metal rod that plugs into my engine block...not sure if your Toyota has that receptacle for the metal rod)?
If you do a search on ecomodder for Engine Block Heater or EBH you should find examples of what other guys use on their cars...maybe even some that are on Corollas.
What part of Maine do you live in? I've been thinking about organizing some type of New England ecomodder meetup in the spring but there's not a whole lot of guys up here. A few in Mass but not alot in New England.
