Hell, I was just going to remove the T-stat after getting a timed baseline for how long it took to idle up to temp, then start periodically putting in smaller radiators until either I started overheating under my normal driving, or I met the time goal.
In Civics, the half sized radiator works every bit as good as the full sized, but I've seen reports of faster warm-up times, partially due to lowered cooling capacity, but also partially due to less coolant to heat up/cool down for each cycle.
