Old 10-09-2009, 03:34 AM   #1 (permalink)
srortega
White 4Runner - '98 4Runner SR5
90 day: 23.21 mpg (US)
Grey Jetta TDI - '011 Jetta
90 day: 42.45 mpg (US)
Computing FE Question
When computing your MPG do you use the odometer in your car or go off the ScanGaugeII? Just discovered that due to non stock tires that I had to adjust the speed on the ScanGauge +2%. I computed the difference and then confirmed it using a GPS and the SG set to KPH. So do I use the mileage from the SG from now on?
