If I remember right, you have a K&W BC-20 charger?
If you do, I have the same one in my EV setup for 96 volts, using a resistor setup I made because I couldn't get my hands on the proper one.
I even have the manual for the charger, and if you want it I can set you up with a resistor setup for a 96 volt, or any other voltage. I have been thinking of making a small board with adjustable settings so I can adjust the charger on the fly, I just haven't done it yet cause I have been lazy.
