10-11-2009, 12:42 PM
#16 (permalink)
Moderate your Moderation.
Originally Posted by Cd
I know that my tank holds somewhere between 10.5 and 11.2 gallons of fuel.
As I get near 9 gallons, I slowly release the trigger to reduce splashing. I then give it fuel in stages. I try to shut off at the first click. *
If you do your math, and the figures just seem a little too high or low, the pump reading may be off. I once filled my tank and found out that the meter was off. The reading had indicated that I had filled up with less fuel than I did. This resulted in an error of several MPG. I therefore would try more than one pump.
One thing I also do is to try and fill in the mornings when the air is cool. This reduces the release of fumes from the tank.
*The problem with this is that a lot of the gas pumps around here do not shut off when they are supposed to, and you never get the 'click' . Instead, it just spills all over your car.
The emissions that result from this are extremely bad since the vapors are going straight into the atmosphere without any filtration. ( Most likely creating more pollution than you would create driving for several miles. )
I'd keep using that pump and find another way to calculate my MPG... if it's ripping off the oil company, I'd be all over it. They've been pick-pocketing us for how long?!
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
