tear = (1) to pull apart (verb); (2) drop of liquid from the eye (noun)
tare = (1) weed (noun); (2) container's weight (noun).
...I meant #1 of (1) above.
...synchro is abbreviation for synchronization-ring, which is an intermediary 'toothed' (usually brass) ring that initially engages the DRIVE rotator, then by friction due to its 'conical' inner surface, slows down the DRIVEN rotator until their two rotational speeds "synchronize" and then the DRIVE and DRIVEN shafts can be locked by sliding spline.
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SIDI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
