Old 10-11-2009, 08:27 PM   #52 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
If I had to guess, I'd probably say it has something to do with how far you go before you hit the neutral detent.
For instance, on my TwinStar, N is all the way down, half click up. On mine particularly, that half click happens closer to 3/4 of the way up, if not a little further. Sometimes, I actually get it into 2nd instead of N, but I can tell by the feel of the click.
I would say that bolt probably adjusts how far up the lever goes before actuating neutral.
The only other thing I can think, and I wouldn't imagine it being correct, is that it adjusts neutral to some other position between gears. Again, I'm sure that's not even close to correct.
