Transmission change needed...looking for input
My wife's 1999 Pontiac Grand Prix SE is in need of a new transmission. Yes, I'd love to replace the car; Yes, I know there are other relatively cheap alternatives out there.
I don't know if it has a 4T60-E (I think so), or the 4T65-E.
I have found that the final drive ratio came in different values. Does anyone know which car had the lowest one? From what I found, it was available down to 2.97, or up as high as 3.74. I don't want to replace it with a short one - I want longer for MPG.
The problem with this is, I've also seen that getting a different FDR requires an ECM change. Any thoughts on this being very bad/causing troubles?
