Old 10-12-2009, 06:45 PM   #7 (permalink)
cjwatts
This is getting fun
well, I keep blowing a fuse. I checked and there is continuity from the computer to the relay and from the relay to the fuel pump. So I am not sure why I am blowing that fuse, maybe a bad ground?Would it be a bad idea to cut the existing ground wire and re ground the pump directly to the body?
Would i be blowing that fuse because of a bad relay? still doesn't explain why I was not gettin power to the relay( blown fuse), but why does the fuse keep blowing?
I am tired and proly not making complete sense...
Thanks for any help!
