Old 03-08-2008, 07:02 PM   #6 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
extragoode -
Welcome to EM! What's your price point? The SG is around $150.
If you want to go hardcore, then I would do a lot of research into a tuner gizmo like this :
Apexi AFC NEO-FUEL "Piggy-Back" Color Display Air Flow Converter Computer - $370
http://www.2kracing.com/product_info...b83c867b5463c3
- Compact "Piggy-Back" Fuel Management Computer (+50% ~ -50%). - Unit incorporates both the SAFC and the VAFC. - NEW "Easy" (8-Point) & "Pro" (16 Point) Modes. - NEW Color FED Display & Interchangeable Button and Background Colors. - Inverting "anti-glare" screen allowing view from both angles. Monitor Mode: - RPM, Throttle, Battery Voltage, Correction %, Air Flow %, Pressure (Kpa), Karmann, VTEC Setting Mode: Air Map, Air Map Graph, Throttle Point, Deceleration Air, VTEC Control, VTEC Unmatch Etc. Mode: MOdel Select, Mode Select, Sensor Select, Analog Select, Warning Set, Display Set, Sensor Check
Hrmmmmm, I don't see MPG in the list above, maybe not so good, .
It's also a lot of upfront cost and that's NOT including installation, which would be more than the super simple "plug it in" ScanGauge. But, I think it could end up giving you more flexibility in the long run.
CarloSW2
American Solar Energy Society
