Old 10-14-2009, 01:42 PM   #13 (permalink)
Sebastian
Originally Posted by AlainB7 View Post
Is it possible to have a l/100km reading?
I know that 235.2/MPG = L/100km
Can be possible to modified it to have this reading?
I'm rewriting the code (based on 0.75m) for european use (L/100km etc). It may be alpha, because I can not test it because of weather atm (motorcycle..).
If someone wants to test it, I will send it to you with pleasure! Then I could correct issues if there are any.. It's also supporting a temperature sensor, if you want to use one.
