Old 10-14-2009, 04:47 PM   #62 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
That cam (13145) is not as easy to modify as I thought.
One option is to grind off the little tang off the gear and move (cut) the inside slot back a tooth (not sure which way back is) and see if you can put neutral between top gear and first and be able to shift all the way round. (big maybe here)
