Old 10-15-2009, 10:56 PM   #3 (permalink)
pgfpro
pgfpro's Avatar
Looks like a nice setup.
Are you running crome gold with datalog capability?
As for tuning timing I made sure that I use the same level streatch of road and just read map values and tps values. I set timing to achieve the lowest tps and highest vacuum values. Then retarded 2 degrees for a safety net.
I did all this while watching knock sensor readings.
Good luck with your project!!!
