Old 10-15-2009, 10:26 PM   #7 (permalink)
Frank Lee
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I saw that.
Exempted parts are add-on or modified parts that have undergone an ARB engineering evaluation. If the part or modification is shown to not increase vehicle emissions, it is granted an exemption to emission control system anti-tampering laws. This exemption is called an Executive Order (EO) and allows the modification to be installed on specific emission controlled vehicles. Every Executive Order part or modification has an assigned number that can be verified by Smog Check stations, BAR Referee stations, or by the ARB.
http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
EO: D-593 View PDF
EO Date: 8/3/2005
Manufacturer Name: Squires Turbo Systems, Inc.
Device: Turbocharger Kit
Device Type: Turbocharger System / Turbocharger Modification
Part_Number: Model_Specification: Modification_Allowed: Remarks:
1999 through 2005 model year General Motors trucks equipped with V8 engines, 2004 and 2005 model year Pontiac GTO vehicles equipped with a V8 engine, and 1998 through 2002 model year Camaro/Firebird vehicles equipped with a V8 engine The Turbocharger Kit includes the following main parts: Garrett turbocharger, model number T04E 60-1 (Trim P, 0.81 A/R turbine, 0.6 A/R compressor), piping from the throttle body to the turbocharger, piping after the muffler to the turbocharger, open element air filter, wastegate, and PCV switch valve. Control module is reprogrammed using a hand held programmer with no user adjustments. Installation requires the air filter to be located near the rear wheel fender. Passenger cars will have an open element filter and trucks may have either an open element filter or a closed element snorkel kit. Boost is limited to 6 pounds per square inch.
EO: D-593-1 View PDF
EO Date: 1/29/2007
Device: Corvette TurboCharger Kit
1997-2005 model year Chevrolet Corvettes
http://www.arb.ca.gov/msprog/aftermk...rmktdevice.php
There are, oh, a zillion turbo kits listed so that in and of itself isn't special or unique.
Oh, I remember what it was about CARB numbers: having one is NOT an endorsement for power or fe increases. It merely doesn't break any laws.
