Old 10-16-2009, 11:51 AM   #14 (permalink)
micondie
micondie's Avatar
moby van - '03 Caravan SE
90 day: 19.74 mpg (US)
Originally Posted by PaleMelanesian View Post
I've measured my blower, and the power draw is proportional to the speed setting - low speed uses less than high speed. Sitting with the engine off, reading battery voltage, and each higher setting drops the voltage another 0.1. Back to a lower setting and that 0.1 comes back. I'm not sure about the why or how, though.
If you are just reading voltage then you haven't measured the power used. You have to measure amperage too. Amps X Volts = Watts (power)
