Old 10-16-2009, 11:34 AM   #16 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Pale is correct. Darin tested this a while ago.
Watts . Item
30 heater fan low speed (1)
49 heater fan 2
66 heater fan 3
81 heater fan high (4)
From: Tested: power draw of Geo Metro accessories & systems (volts, current/amps, watts)
Since I run with my alternator disabled, and now that it is fairly cold in the morning, I'm still very careful about using the fan. As Darin found out, his fan can consume more power than his car requires to run the engine! That, plus the addition of using headlights is a large drain to the battery. If I can avoid it, I don't use it.
