Old 10-17-2009, 12:02 AM   #3 (permalink)
dieselescort
vdub - '86 Jetta GL
90 day: 47.64 mpg (US)
You should not mix and match because synthetic when combined with standard oils will cause foaming. Most likely it's standard petroleum oil unless it seems like the previous owner was into performance mods...which with a Metro is probably not the case!
'scort no longer- '86 VW Jetta diesel - biodiesel
