Sorry to be a party pooper but an induction motor would require an expensive controller and high power inverter.
A given motor will put out roughly double the hp and rpm with double the voltage. They like to run at a certain rpm and will put out many more hp to get there if loaded up. You can "safely" double the voltage/HP of a motor but have to watch out not to overheat it and probably not run it continuously at double It's rating . I use a $10 digital oven thermometer to keep tabs on my bikes.
For an easy contactor motor EV set up I would look for a used permanent magnet brushed motor. Can be found cheap if you know where to look. Old forkifts, etc. Look for H rated motors (can be run the hottest: low-A, B, F, H-high)
Brushed PMDC is 2 wires, no waiting. Fairly simple to set up a series parallel contactor arrangement. That's how the Auranthetic bikes are set up. They are rated 1 hp cont. but probably put out 3 or more up hills.
"I'd love to have an affordable, efficient hydrogen car. I'd park it next to my unicorn"
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
