Old 10-19-2009, 02:48 AM   #19 (permalink)
Frank Lee
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Both layouts place the ball in line with the rod. The balls-n-sockets on both layouts see the same strain; it is the bolt or stud that has to deal with "leverage".
If you are placing the ball closer to the knuckle, you are changing the geometry. And, you are not putting a nut up there to hold the bolt like you said. Or, you are putting a nut between the knuckle and the joint, keeping the geometry and subjecting the bolt to the same "leverage" as a tie rod end stud, but basically making a neo-tie rod end from what I can tell.
