Old 03-09-2008, 07:48 PM   #83 (permalink)
LostCause
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
I realize the competition is over, but hopefully there are some new ideas in there others can use. I tried to keep the mods somewhat practical, so I kept the "dreaming" type stuff out. There are a few borderline though..
Listed by order of occurance...
1997 Ford Escort Wagon MPG Project
2.0 SPI 4cyl Gasoline Engine
Manual Transaxle
Juuust Kidding, but the list is real.
Engine (Factory 2.0 SPI Engine):
-0W20 Synthetic Oil
-Freeze Plug Block Heater
-Power Steering Delete (Manual Rack Conversion)
-A/C Delete
-Alternator Delete
***2 Prius Subpacks for battery
***14v bank of Maxwell Supercapacitors
-Smaller Radiator
***Ducted w/ Adjustable/Closable Opening or Exit
-Stainless Steel Headers w/ Heatwrap
-Insulate Radiator Coolant Lines
Trans:
-VW G52 Transmission Fluid
-2.88 Final Drive Transaxle from 80’s Pony Escort Model
Exterior (All aero additions are fiberglass composite):
-Antenna Delete
-Side Mirror Delete (use Interior Mirrors)
-Rear Wheel Fairing
-Front Wheel Fairing a la Basjoos
-Kammback
***15 degree angle top and sides
***Extend just past bumper
-Completely Smooth Underbody Panel
***15 degree Diffuser at rear
-Side Skirts to road
***Rigid (Upper Half)
***Flexible (Lower Half)
***Approxiamately Wheel Width
-Boattail each Rear Wheel Fairing
-Splitter in front of each Front Wheel Fairing
-Custom Body Panels
***Reshaped Nose w/ intake to radiator duct
***Fiberglass Composite Hood, Fenders, Quarter Panel, etc.
***Airtight Engine Compartment except for intentional vents
-All glass except windshield & side windows replaced with plexiglass
-Tape all seams
-Clay Bar surface, wax, and keep immaculately smooth
-Bend Windshield Wiper arms so they sit under hood
Interior:
-FE Instrumentation
-Cabin Vents Always Open (no fan)
-Window cranks removed to prevent temptation
-All Carpet and Sound Deadening Material Removed (weight savings).
-Interior Gutted: Everything behind driver's seat removed (weight savings).
-Interior Lamps replaced with LEDs
-Radio Removed
-Anything electrical and nonessential removed
Suspension/Wheels:
-Ensure brakes aren't dragging
-Repack wheel bearings w/ lightweight, synthetic grease/oil mix
-0 Toe, 0 Camber alignment
-13" Wheels (Mag or Aluminum if possible)
-LRR, 155 "skinny" tires w/ as large a diameter as possible
-50+psi
-Lowering Springs (5-6" frame height
-Stiff Shocks
-Rear Wheel Disc --> Drum Swap if lighter (many are)
-Mooneye Hubs
Other:
-HID headlights (pulls 55w vs 65+w)
-LED replacement for other external lights
-SunPower box of A-300 cells on hood and roof to charge Prius Subpacks
-Spare Tire delete
-White Paint Job to cut down on solar heating
-Engine Kill Switch/Starter
-Smaller Gas Tank or buy Half Tanks @ a time
-Exercise and lose weight
Driving Techniques:
-Engine Off Coast (any decceleration over 5-10 seconds) and Stops
-Quick, low-rpm acceleration
-55mph max speed
-Drive "without brakes"
-Clutch Start whenever possible
-Drive during day if possible
To Save Money:
-Double Clutch
-Buy gasoline when it is cheapest to fill car and airtight 20 gallon jerry can (kept in cool location to limit evaporation)
-Replace synthetic oil & filter every 10,000 miles
-Buy Liability Insurance only (but not bare minimum)
-Link journeys together, drive during non-rush hour only
- LostCause
