Old 10-19-2009, 11:39 AM   #3 (permalink)
Johnny Mullet
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
With those compression numbers, I suspect you are due for a rebuild. I highly recommend replacing the exhaust valves with stainless steel ones so they will not burn in the future.
The Metro will run with compression numbers as low as 90 or even less, but will not run well. Here are some threads that may help you do the entire rebuild yourself saving you lots of money..............
1.0L Head Repair Guide
Bottom End Rebuild Guide
Mrs. Mullet's Extreme Metro Makeover
The Weekend Rebuild
Good luck!
The Following User Says Thank You to Johnny Mullet For This Useful Post:
Christ (10-19-2009)
