Old 10-19-2009, 12:30 PM   #22 (permalink)
jamesqf
Originally Posted by greasemonkee View Post
Since current is constant through the entire series circuit, the resistors are in fact "burning up" wattage, they're burning up voltage to be specific.
A resistor is not a transistor.
Sure. I was trying to give a simplistic explanation, without invoking Kirchoff's Law &c. But try a simple experiment: take a 12-volt battery, and connect a piece of copper wire (low resistance) between the terminals. Lots of current flow, heat, sparks, etc - and in particular energy "burned up". Now put a piece of wood (very high resistance) between the terminals. Does the wood start to smoke & catch fire from all the energy it's burning up? No, because current isn't flowing because of the resistance.
ETA: Or consider the transistor: it's a device that's switchable between two states, high and low resistance. When it's in the high resistance state, is it "burning up" the power that's not flowing through it?
The Following User Says Thank You to jamesqf For This Useful Post:
gascort (10-22-2009)
