Thread: Cougar shape?
Old 10-19-2009, 05:50 PM   #16 (permalink)
wyatt
Suzi - '94 Swift GA
90 day: 48.94 mpg (US)
Prius II - '05 Prius Package 6
90 day: 46.51 mpg (US)
Rear Window Angle
As far as the sharp rear window goes, it probably doesn't do much to hurt you. In Hucho's book, you will see that drag goes down with a rear slope of up to ~15 degrees, then get's worse to ~30 degrees, and after 30, it GETS BETTER and stays flat from there on. So unless you are going to put a 15 degree trailing end on the car, try the spoiler idea.
*this is all from memory, so I will have to look when I get home, anyone feel free to chime in and correct me*
