Sounds good! The head bolts and stainless valves are cheaper from 3Tech than the standard parts and a much better deal. If you would like to get better fuel economy, consider the Economy grind camshaft from 3Tech. It is a proven instant 5 MPG increase! Combine that with an advanced timing gear and you really got something going!
Oil pumps normally don't go bad even with high miles. Yours may haave some internal wear, so replacing the pump is not a bad idea.
