Old 10-19-2009, 11:40 PM   #25 (permalink)
jamesqf
Originally Posted by micondie View Post
The reason a piece of wood won't get hot is that there is no current flowing through it to generate any.
Yes, that's exactly my point. You don't have as much current flowing through a resistor (V = IR, remember?), so less energy flow, so no heat. But don't take my word for it, look at a basic electric/electronics text, or put a temperature probe on one of those resistors that are supposed to be turning energy into heat.
Oh, and another question for thought: how come the wires in your toaster or electric heater - or indeed, the tungsten filament in an incandescent light bulb - are made of metal, which has a low resistance? Just for the heck of it, I dug out a few old incandescent bulbs, and measured their resistance: 40 W = 30 ohms, 60 W = 17 ohms, 75 W = 13 ohms. Not high resistance at all (though of course it increases with temperature), yet lots of heat.
Why do you think they mount power transistors on a heat sink?
Why is your CPU mounted on a heat sink with a fan?
Remember the transistor is a semiconductor. It's generating heat when current is flowing, and that's when it's in its lower resistance start.
The Following User Says Thank You to jamesqf For This Useful Post:
gascort (10-22-2009)
