you know thats actually kinda scary, cuz after i read your post i went to revise my diagram, and my revision looks almost exactly the same as yours. Spooky!!! lol. anyway, with my conversion im more concerned with range than speed. i want it to be able to go at least 90 kh/h, which is pretty standard i think, but i want at least the same in range. now if my understanding is correct, the lower the current is with an appropriate amount of cells attached, the farther you can travel on a single charge. Simply put higher voltage equals higher speed, coupled with lower current equals longer range. am i right about that, or does it work a different way??
