Old 10-20-2009, 03:45 PM   #8 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
Range
Originally Posted by angelarm1110 View Post
you know thats actually kinda scary, cuz after i read your post i went to revise my diagram, and my revision looks almost exactly the same as yours. Spooky!!! lol. anyway, with my conversion im more concerned with range than speed. i want it to be able to go at least 90 kh/h, which is pretty standard i think, but i want at least the same in range. now if my understanding is correct, the lower the current is with an appropriate amount of cells attached, the farther you can travel on a single charge. Simply put higher voltage equals higher speed, coupled with lower current equals longer range. am i right about that, or does it work a different way??
There's no free lunch, or everything would be run at super-high voltages. If you set a pack up for higher voltage, the amperage goes down. The available watt-hours remain the same, but higher speeds use them up faster, so range goes down more than travel time.
