Old 10-20-2009, 05:42 PM   #9 (permalink)
captainslug
Misanthropologist
captainslug's Avatar
BORK! - '89 240 DL Wagon
90 day: 21.27 mpg (US)
If your DC converter isn't powering very much you should be putting the ignition between the battery pack and it. Unless of course the DC converter itself has its own On/Off pins that you could wire the ignition to.
As your system is laid out now everything connected to the DC converter would be on all the time.
My wiring schematic became pretty detailed long before I even started working on the wiring.
