Old 10-20-2009, 04:52 PM   #10 (permalink)
angelarm1110
my understanding was that if there was no load on any of the 12 volt applications, then the converter wouldn't be drawing any power from the cells, however if that is not the case (which now that i think about it, probably isn't), then perhaps i should make sure to find one with on/off pins like you said, and wire that to a switch on the handle bars or something.
