I am not sure where to find the motor serial and tag, I don't see it on the motor. I wasn't aware that the shaft was so strange, although I am not surprised. Some custom lathe work should be able to solve that hurdle if necessary, although it is costly.
I am still learning with this project, but how wouldn't a bigger motor yield greater performance? For example, the D&D ES-31B is a 72-120 volt motor that is rated at 25 HP continuous, 40 HP Peak. I know range is sacrificed, but wouldn't this motor provide greater speed? Or are my gear ratios restricting too much to make a difference?
Regarding the batteries, I can't tell you what happened to them before I got them, but those 3 appear to still work. I may end up in the midwest sometime in the next 3-6 months, but if we can work out a way to migrate them to you before then I say let us do that!
