Ditto the above points.
It's a lot to ask for $300.
I'd also consider revising your goals, especially the top speed goals. Any motorized bike capable of over 20mph is subject to the same licensing restrictions as motorcycles. Plus 30mph on a bike is flat hauling-you know what.
A hub motor would be fairly easy to remove quickly, just disconnect the wires and swap your wheel. Then you'd have battery removal to worry about.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
