Old 10-21-2009, 07:10 PM   #5 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
Originally Posted by bbenny View Post
Hello Stou0220, Might be interested in the device(is it from Mark D. in Ohio?). I too have an 07 zx40s, which I think has the Chinese motor and controller. Just learning about my car. Were you able to upgrade the SPEED? ? ? Thanks, Don
If you want your top speed to go up several MPH just air your tires up to 50psi (or live dangerously and go to 60psi like I do)
Given that the tires on the miles are rated at 44psi at 120mph I would estimate your safe at 50psi at 30ish mph.
In regards to the device, field reduction will increase your speed but also draws more amps, I don't think he installed the device but I am curious if it was fully automatic (no button) or engaged once you got to a certain speed.
Cheers
Ryan
