...what's the voltage right at the battery terminals at idle? Should be about 12.6Vdc or higher? If not, it STILL could be a bad regulator (internal) or even bad diodes (also internal).
...if you 'slightly' rev the engine, does the voltage go "UP" to something above 12.6Vdc? If not check & clean all grounds (again). The alternator "output" voltage should go UP with engine speed somewhat, but not exceed about 14-14.5Vdc depending upon temperature.
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SIDI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
