Old 10-21-2009, 08:30 PM   #342 (permalink)
basjoos
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 70.97 mpg (US)
The low ground clearance and the side skirts make it difficult to get good photos of the underside. I need to get the car up on a lift to get good underside photos. Routing the cooling air out through the front wheel wells was easy. Large openings for the FWD drive shafts were already present on the car, so once I underpanelled the underside of the engine compartment, the cooling air had nowhere else to go but out through the drive shaft openings (some cooling air also runs out through the exhaust tunnel to the right rear wheel well).
My car was on display today at the Rutherford County High School, where my sister in law teaches and asked if I could bring the car by for their science and technology classes to see. I heard some of the students went to the library immediately afterwards to start researching the subject of low drag cars. Ecomodder also got some exposure.
Confirmed lean burn up through 91mph. Still haven't reached the max speed for lean burn.
aerocivic.com
The Following User Says Thank You to basjoos For This Useful Post:
aerohead (10-24-2009)
